d.mon
    Zhian Li
    zhian_li at agcs.cas.psu.edu
    Fri Dec 16 16:34:52 EST 1994
_______________________________________________________________________________
From: grassu-list at moon.cecer.army.mil on Fri, Dec 16, 1994 16:31
Subject: d.mon
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: grassu-list at max.cecer.army.mil
I am using grass on a Sun SPSARC5 running Solaris.  Recently, I tried
to use "d.mon start=x0".  The x0 window is created, but then the GRASS
prompt is not returned.  Also, if I control-C to break out, GRASS seems
to think the window is still active.
John
Are sure your .grassrc file is set correctly.  You may have made the window
too small.  Check it first, it may give you some hint.
