HP DRIVER
KLENKUS1 at VAXC.STEVENS-TECH.EDU
Wed Feb 2 12:31:10 EST 1994
Javier,
There is no driver that I am currently aware of for a HP 500C.
The solution to the problem can be easily solved by getting
ghostscript from ftp.cpsc.ucalgary.ca in pub/gnu. This
program will translate postscript to a form your hp550c will
understand.
Within GRASS use the ps.map command to get the postscript
file and then use ghostscript.
Hope this helps.
Kym M. Lenkus
Davidson Laboratory
Stevens Institute Of Technology
Hoboken, NJ 07030
