Lines in the vector file
garvinc at sill-emh.army.mil
GARVINC at SILL-EMH.ARMY.MIL
Wed Feb 2 14:03:57 EST 1994
In reply to your request to bulk remove unlabeled lines... In v.digit, under
edit there is a function called R (remove BLOCK of lines) This will allow you
to use either your mouse or digitizer puck to enclose an area and remove the
lines within it. This will work for both labeled and unlabeled lines.
If you have questions call me at (405) 442-3314 or 6174.
Chris D Garvin FT SILL, OK
