xgdisplay bug fix.
ray at zoro.cts.com ray at zoro.cts.com
Fri Feb 4 18:24:19 EST 1994
I have found a bug and a fix for modify color mode in
xgdisplay when you are changing colors assigned to categories
and then try to save the modified color, the color file
is wiped out. The problem is in:
grass/src/xgrass/display/crtecolor.c line:214
  G_write_colors(Gobj->Obj.GeoFrame.rname, Gobj->Obj.GeoFrame.rmapset,
                 Gobj->Obj.GeoFrame.colors);
it should be:
                 &(Gobj->Obj.GeoFrame.colors));
i.e. The address of Gobj->Obj.GeoFrame.colors.
Enjoy.
<ray>
