XKeysymDB file
Ken Sibley ksibley at ncg.scs.ag.gov
Thu Feb 10 13:13:56 EST 1994
This is a message I posted a few weeks ago.  Please forgive all of the
header info, but I had to pull it out of a saved list.  I think the
information still applys to what you are asking.  If this is not enough
info then you should check the grassu archives as this topics has been
tossed around a lot during the months of Jan/Feb 94.
Ken Sibley
USDA-SCS
----- Begin Included Message -----
>From ksibley Thu Feb 10 10:51:40 1994
Date: Thu, 10 Feb 94 10:51:40 CST
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: ksibley
Subject: Re: Help with XKeysymDB file
Content-Length: 1944
>From grass-lists-owner at max.cecer.army.mil Mon Jan 31 16:06:32 1994
Date: Mon, 31 Jan 94 15:58:36 CST
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Content-Length: 1546
> From grass-lists-owner at max.cecer.army.mil Mon Jan 31 15:48:44 1994
> Date: Mon, 31 Jan 94 13:57:38 EST
> From: ld+0075!dotson at uu5.psi.com (Doug Dotson)
> Content-Length: 544
> I had a similar experiance when I downloaded the binaries.  I never did figure
> out why it happened and several from this list offered suggestion of which
> none worked.  For other reasons I downloaded the source and did a complete
> rebuild including XGRASS.  The problem went away.  This suggestes that the
> keysym table is compiled into the code.  I was not under the impression that
> this was the case, I thought the it was dynamically loaded at runtime.  I
> never persued it further since my purposes were satisfied.
> Doug Dotson
> dotson at tate.com
This is similar to our experiance.  The messages that I posted about two
weeks ago were for the binaries (of xdigit) that we downloaded from CERL.
We have since recompiled xdigit, with update 3 installed, and the XKeysymDB
warnings came back.  Using the strings command that I posted the note about
before showed two things:
%s/lib/XKeysymDB
/usr/openwin/lib/XKeysymDB
I then appended the motif XKeysymDB file to the /usr/openwin/lib/XKeysymDB
file and the warnings went away.  I did not have time to find where the
%s/lib/XKeysymDB message came from; more pressing things popped up.
Ken Sibley
USDA-SCS
----- End Included Message -----
