Vector Cleaning
    Tom Hawkins
    hawkins at water.ca.gov
    Thu Feb 10 19:12:59 EST 1994
We have created vector data in another package (Autocad) that we're bringing
into GRASS.  Unfortunately, the data created does not always have nodes at
line intersections (in Autocad).  When brought in as a DXF file, and
inspected in v.digit, we can see all the missing nodes.  We used v.spag, and
it did create nodes and cut off the resulting dangling lines, but only at
those points where the lines actually touched (intersected).  Most of the
lines that were supposed to be intersected are not in GRASS (they are in
Autocad).  By zooming in a dozen or more times in v.digit, it's apparent
that the lines are not touching (the distance between the endoint and the
intended intersection point is around 0.0001 meters).
Does GRASS have a program to extend dangling lines to another line, then
break the line at that intersection?  There are far too many
non-intersecting points in each file (and we have dozens of files) to do
manually.
Thanks for any help.
Tom Hawkins
