v.in.arc label-text file
    Oliver Weatherbee
    oliver at earthview.cms.udel.edu
    Fri Feb 25 10:41:04 EST 1994
In article 01H9AQM8DYF69JD203 at VAXC.STEVENS-TECH.EDU, KLENKUS1 at VAXC.STEVENS-TECH.EDU writes:
> If I understand your problem correctly the data will transfer
> into grass fine, but you can not import it with the text
> file attached.
> Look at your text file and it will probably look like the
> following:
> 2  NW  Unionville NY-NJ           0032
> 3  NW  Port Jervis South NJ-NY    0011
> ...(helpful suggestion deleted)...
Actually, I am not sure HOW to generate the text file at all from Arc/Info.  I am
trying to import the NOAA coastal framework data which delineates various estuarine,
fluvial, and coastal drainage areas and although I am having no problems bringing in
the actual vectors, I am stumped as to how to include the polygon attribute data i.e.
the data in the arc/info .pat file.
Oliver Weatherbee
