Arc/Info dxf file to Grass vector
Malcolm Williamson malcolm at cast.uark.edu
Wed Jan 5 15:35:14 EST 1994
> Hi Ron!
> I can say that Arc/Info dxf file can be converted into GRASS vector.
> But the right way to do it is creating DLG format in ArcInfo and
> then bring DLG file into GRASS through v.import command. From my
> experience, the v.in.dxf or v.in.arc are not working commands.
Sorry, couldn't pass this one up. I have successfully used v.in.arc under both
4.0 and 4.1 - it's just a little *tricky*. Specifics have been posted to both
this list and esri-l several times; let me know if you need a copy.
v.in.dxf works, but doesn't import attributes for line data. Not the best way
to go, unless no attributes are involved.
> If you have any questions, give me a call at (914)742-2085.
> Yuri.
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
