FRAGSTATS: A Spatial Pattern Analysis Program
Tom Moore
tmoore at pnfi.forestry.ca
Fri Jan 7 13:10:59 EST 1994
Anyone interested in measures of landscape structure?
Kevin McGarigal and Barbara Marks of Oregon State University
have developed a program named FRAGSTATS that reads in a variety
of raster data formats, and computes a comprehensive set of measures
from the field of landscape ecology. Although GRASS format is not
supported explicitly, it is easy to convert GRASS datasets into the
ASCII file format. I have a bit of experience with this program, and
can vouch that it seems to work very well, there is a rich set of
statistics, and the documentation is superb. Attached is a
notice from authors about FRAGSTATS and how to obtain it.
Tom
--------- Included Notice -----------
FRAGSTATS
McGarigal and Marks have developed a spatial pattern analysis
program, FRAGSTATS, for quantifying landscape structure. Two
separate versions of FRAGSTATS exist; a raster and a vector version.
The raster version is a C program that accepts landscapes in the
following formats: ASCII, 8 or 16 bit binary, Arc/Info SVF files,
ERDAS image files, and IDRISI image files. The vector version is
an Arc/Info AML that accepts polygon coverages. The AML also calls
several C programs. Both versions of FRAGSTATS generate the same
array of metrics, including a variety of area metrics, diversity
metrics, and contagion and interspersion metrics. The raster
version also computes a variety of nearest-neighbor metrics.
All C programs were developed on a Sun Workstation under Unix
and compiled with the GNU C compiler. The Arc/Info AML was developed
with Arc/Info version 6.1; it will not run with earlier versions of
Arc/Info. A PC version of the raster FRAGSTATS program is also
available. A 386 or better machine and a math coprocessor are
required.
The software is available from the following FTP site:
ftp.fsl.orst.edu
login: anonymous
password: your email address
cd pub/fragstats.1.0
Please read the letter (readme.ps) and the documentation in the man
directory. These are postscript files. See the fragstats.doc ASCII
file in the raster and vector directories for installation and running
instructions. Hard copy documentation and a floppy are available for
$25 for those unable to obtain the programs electronically. Make
checks payable to Kevin Mcgarigal and mail to the address listed below.
Kevin McGarigal Barbara Marks
P.O. Box 606 Dept of Forest Science
Dolores, Colorado 81323-9998 Oregon State University
(303) 882-2114 Forest Science Lab 020
Corvallis, OR 97331-7501
(503) 750-7287
marks at fsl.orst.edu
