"noisy" programs
Mark P. Line
markline at henson.cc.wwu.edu
Thu Jan 13 00:35:56 EST 1994
On Wed, 12 Jan 1994, Darrell McCauley wrote:
> grass programs may be naturally verbose and have a -q (quiet) flag, or
> grass programs may be naturally terse and have a -v (verbose) flag.
> Which situation is preferred by users?
Verbosity is often disconcerting to experts. Quietude is often
disconcerting to novices. Since you can't have both default behaviors
simultaneously, I would suggest implementing an environment variable such
as DEF_QUIET which, when defined, causes all programs that care about it to be
QUIET by DEFault, unless verbosity is forced by -v on the command line. If
DEF_QUIET is undefined, then all programs that care about it would be
verbose by default, unless quietude is forced by -q on the command line.
The default setting for DEF_QUIET itself should probably be "undefined",
since the users of a freshly installed GRASS will probably be novices more
often than not (or so one might safely assume).
-- Mark
Mark P. Line Phone: +1-206-733-6040
Open Pathways Fax: +1-206-733-6040
P.O. Box F Email: markline at henson.cc.wwu.edu
Bellingham, WA 98227-0296
