r.in.arc.p
Greg Koerper
greg at dubious.cor2.epa.gov
Thu Jan 13 19:59:39 EST 1994
Here's a simple perl script for converting existing ARC ascii grid data into
GRASS raster format. It could be called from an aml for further efficiency.
#!/usr/local/bin/perl [change this as necessary for your site]
# r.in.arc.p [-N] input output
# converts an ascii ARC grid layer to a GRASS raster
# -N prevents conversion of null data values to 0 (default: convert to 0)
require "getopts.pl";
&Getopts ('N');
# set parameters by default or argument
$zero = $opt_N ? 0 : 1;
print "reading ARC header, writing GRASS header\n";
$file = shift (@ARGV);
open (ARC, $file);
open (GRASS, "> $file.$$");
$raster = shift (@ARGV);
for ($i = 0; $i < 6; $i++) {
$_ = <ARC>;
($dummy, $value[$i]) = split (' ');
($cols, $rows, $west, $south, $res, $null) = @value;
$east = $west + ($cols * $res);
$north = $south + ($rows * $res);
print "writing data values . . .\n";
print GRASS "north:\t$north\nsouth:\t$south\neast:\t$east\nwest:\t$west\n";
print GRASS "rows:\t$rows\ncols:\t$cols\n";
while (<ARC>) {
if ($zero) {
s/$null/0/g;
print GRASS;
close ARC;
close GRASS;
print "reading GRASS ascii into raster format . . .\n";
system "r.in.ascii $file.$$ o=$raster";
# system "rm $file.$$";
print "done\n";
Greg Koerper Internet: greg at heart.cor.epa.gov
ManTech Environmental Technology, Inc.
US EPA Environmental Research Lab voice: (503) 754-4490
200 SW 35th St., JSB fax: (503) 754-4338
Corvallis, OR 97333
