making slides
Ken Sibley
ksibley at ncg.scs.ag.gov
Wed Jan 19 18:11:42 EST 1994
> GRASS users--
> Has anyone succeeded in making slides directly from GRASS images, as
> opposed to photographing the screen? If so, how did you do it?
> I have just tried making an X window dump, then using pbmplus to
> convert the result to a TIFF file for importation into Harvard
> Graphics, e.g.:
> Pbmplus does not seem the way to go.
> That being the case, has anyone succeeded with another approach?
> Thanks in advance for any advice. Since this sounds like something
> that might be of general interest, I will summarize for the net.
> Michael Camann camann at dial.pick.uga.edu
> Department of Entomology camann at phoenix.cs.uga.edu
> University of Georgia (706) 542-1388
> Athens, GA 30602 (706) 542-2276
Michael,
I think that this has been talked about a little before so you may have to
do some research. I think the trick is to use the CELL driver first, see
Malcolm D. Williamson's message from ~Jan 14, 1994. You can then use
the src.contrib/SCS/... program r.out.tiff to create the tiff file.
We have been able to do this and then take the tiff into a slide maker
program on our Mac's. If you need more info I can try to dig up some
notes from the people who actually did the work here.
Hope this helps,
Ken Sibley
USDA-SCS
