v.proj from utm to state plane
John L Sparco sparco at bach.udel.edu
Thu Jan 27 09:50:01 EST 1994
I am trying to convert vector areas from utm to state plane using v.proj.
When the conversion is done, most of the areas don't transfer.  If I look
at the dig_att file, it appears to be trashed.  Instead of
   A  easting  northing  cat,
I get
   binary garbage  easting northing cat.
Some areas have only one coordinate.  Others are dropped completely.  Both
locations have valid PROJ_INFO files.  I found a reference to improperly
formatted coordinates in v.proj under BUG_FIXES but it is not in updates
1-3.  I also found a footnote in the programmer guide that state plane is
not fully supported.  Which of these, if any, is my problem?
John Sparco
