r.in.sunrast
martijn at scanner.frw.uva.nl
Mon Jul 4 05:18:17 EDT 1994
On Fri, 1 Jul 1994 CSCI2662 at CL.UH.EDU wrote:
> Is this setting of the region thing done befor or after you use the
> r.in.sunrast routine.
I think this brings up a more general point, which is that to my
knowledge all importing and exporting tools (should) disregard whatever
the current region and mask settings are, and just convert the data in
the source map to its equivalent in the target map. So r.in.sunrast
should not be affected be the region settings.
P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam martijn at scanner.frw.uva.nl
