postscript cont.
    Andrea Giacomelli
    andreag at idra1.iar.polimi.it
    Mon Jul  4 14:25:25 EDT 1994
> Sort of related question - I've managed to compile 'ghostscript' so I can
> look at the output from 'ps.map' - I've tried to compile 'ghostview', but
> it fails because it can't find the 'Xaw' directory, which contains some
> '.h' files, e.g. Cardinal.h'
> It seems that these files are something to do with 'Athena' ?? - any idea
> what this is ?  - is it like Motif ?
> More importantly, if it is PD, where can I get hold of the files
> necessary to compile ghostview on a Sun IPX ?
> Thanks for any help,
the Xaw library contains some widgets required for the compilation.
You can retrieve them from many sites. I work on HP, and I ftp-ed them
from a dedicated server, but I think that you may find them around.
You can try through the 'archie' service:
1- telnet on one of the following (user: archie, no password):
    archie.au                   139.130.4.6     Australia
    archie.uni-linz.ac.at* 	140.78.3.8      Austria
    archie.univie.ac.at*        131.130.1.23    Austria
    archie.uqam.ca*             132.208.250.10  Canada
    archie.funet.fi             128.214.6.100   Finland
    archie.cs.huji.ac.il        132.65.6.15     Israel
    archie.wide.ad.jp           133.4.3.6       Japan
    archie.sogang.ac.kr*        163.239.1.11    Korea
    archie.hana.nm.kr*		128.134.1.1	Korea
    archie.luth.se*             130.240.18.4    Sweden
    archie.switch.ch*           130.59.1.40     Switzerland
    archie.ncu.edu.tw           140.115.19.24   Taiwan
    archie.doc.ic.ac.uk         146.169.11.3    United Kingdom
    archie.unl.edu              129.93.1.14     USA (NE)
    archie.rutgers.edu*         128.6.18.15     USA (NJ)
    archie.ans.net              147.225.1.2     USA (NY)
    archie.sura.net             128.167.254.179 USA (MD)
    archie.luth.se
    archie.unipi.it
2- type the command 'find [string]', e.g. 'find Xaw'
3-  "   "     "    'mail [user at ....]'
You will receive a list of sites on which Xaw is available.
Good work!
					Andrea Giacomelli
					DIIAR Politecnico di Milano, Italia
