mapgen
    Jim Nolan
    jnolan at tecsun1.tec.army.mil
    Thu Jul 14 13:30:07 EDT 1994
Here is a more detailed summary of my problems with mapgen.
What follows is the section where the failure occurs.
I do not have a gcc compiler but am using gmake4.1 and
am confused as to if I need a gcc compiler. If so what for?
I am compilig this on a Sun Sparc 10 SunOS 4.1.3.  My
make.rules file gives me no clue as to what may be the problem.
I get the same problem if I am logged in with my own account
or root.  This is the latest version of mapgen that is located
on the moon.  Thanks for any help that can be offered.
Jim
jnolan at tec.army.mil
#####Errors
/usr/local/bin/gmake4.1 mapgen/src
  SRC     = /j6/grass/grass4.1/src
  CMD     = /j6/grass/grass4.1/src/CMD
  HEADER  = sun4
  ARCH    = sun4
  GISBASE = /j6/grass/grass4.1/sun4
  VERSION = 4.1 Spring 1993 Update package 4
/j6/grass/mapgen/mapgen/src
  make -f OBJ.sun4/make.rules
rm -f OBJ.sun4/points.o
cc -I../../graphics/plotter -I../include -O -c points.c
mv points.o OBJ.sun4/points.o
cc -s -o /j6/grass/grass4.1/sun4/mapgen/bin/points OBJ.sun4/points.o  ../../lib/LIB.sun4/libgen.a ../../lib/LIB.sun4/libgraph.a -lm
ld: ../../lib/LIB.sun4/libgen.a: warning: table of contents for archive is out of date; rerun ranlib(1)
ld: ../../lib/LIB.sun4/libgraph.a: warning: table of contents for archive is out of date; rerun ranlib(1)
ld: Undefined symbol
   _adjst_name
   _dmstor
   _bchload
   _bcheval
   _pclip
   _dsk_acs
   _clip
   _lrnd
*** Error code 2
make: Fatal error: Command failed for target `/j6/grass/grass4.1/sun4/mapgen/bin/points'
Current working directory /j6/grass/mapgen/mapgen/src
*** Error code 1
make: Fatal error: Command failed for target `all'
