mapgen
Jill Schuler jschuler at ncg.scs.ag.gov
Thu Jul 14 15:38:23 EDT 1994
%%%From grass-lists-owner at max.cecer.army.mil Thu Jul 14 12:45:51 1994
%%%From: jnolan at tecsun1.tec.army.mil (Jim Nolan)
%%%Subject: Re:mapgen
%%%Sender: grass-lists-owner at max.cecer.army.mil
%%%Reply-To: grassu-list at max.cecer.army.mil
%%%To: grassu-list at max.cecer.army.mil
%%%Date: Thu, 14 Jul 1994 13:30:07 -0400 (EDT)
%%%X-Mailer: ELM [version 2.4 PL23]
%%%Mime-Version: 1.0
%%%Content-Type%%%: %%%text/plain%%%; %%%charset=US-ASCII%%%
%%%Content-Transfer-Encoding: 7bit
%%%Content-Length: 1718
%%%Here is a more detailed summary of my problems with mapgen.
%%%What follows is the section where the failure occurs.
%%%I do not have a gcc compiler but am using gmake4.1 and
%%%am confused as to if I need a gcc compiler. If so what for?
%%%I am compilig this on a Sun Sparc 10 SunOS 4.1.3.  My
%%%make.rules file gives me no clue as to what may be the problem.
%%%I get the same problem if I am logged in with my own account
%%%or root.  This is the latest version of mapgen that is located
%%%on the moon.  Thanks for any help that can be offered.
%%%Jim
%%%jnolan at tec.army.mil
%%%#####Errors
%%%/usr/local/bin/gmake4.1 mapgen/src
%%%  SRC     = /j6/grass/grass4.1/src
%%%  CMD     = /j6/grass/grass4.1/src/CMD
%%%  HEADER  = sun4
%%%  ARCH    = sun4
%%%  GISBASE = /j6/grass/grass4.1/sun4
%%%  VERSION = 4.1 Spring 1993 Update package 4
%%%/j6/grass/mapgen/mapgen/src
%%%  make -f OBJ.sun4/make.rules
%%%rm -f OBJ.sun4/points.o
%%%cc -I../../graphics/plotter -I../include -O -c points.c
%%%mv points.o OBJ.sun4/points.o
%%%cc -s -o /j6/grass/grass4.1/sun4/mapgen/bin/points OBJ.sun4/points.o  ../../lib/LIB.sun4/libgen.a ../../lib/LIB.sun4/libgraph.a -lm
%%%ld: ../../lib/LIB.sun4/libgen.a: warning: table of contents for archive is out of date; rerun ranlib(1)
%%%ld: ../../lib/LIB.sun4/libgraph.a: warning: table of contents for archive is out of date; rerun ranlib(1)
%%%ld: Undefined symbol
%%%   _adjst_name
%%%   _dmstor
%%%   _bchload
%%%   _bcheval
%%%   _pclip
%%%   _dsk_acs
%%%   _clip
%%%   _lrnd
%%%*** Error code 2
%%%make: Fatal error: Command failed for target `/j6/grass/grass4.1/sun4/mapgen/bin/points'
%%%Current working directory /j6/grass/mapgen/mapgen/src
%%%*** Error code 1
%%%make: Fatal error: Command failed for target `all'
The mapgen src code was written, as I understand, to compile using the
gcc compiler.  We "SCS" used the gcc compiler and the compile ran smoothly.
