mapgen
    Gerald I. Evenden
    gie at charon.er.usgs.gov
    Thu Jul 14 20:58:16 EDT 1994
>Date: Thu, 14 Jul 94 14:38:23 CDT
>From: jschuler at ncg.scs.ag.gov (Jill Schuler)
>To: jnolan at tecsun1.tec.army.mil, grassu-list at max.cecer.army.mil
>Subject: Re:mapgen
>Cc: jschuler at ncg.scs.ag.gov
>%%%From grass-lists-owner at max.cecer.army.mil Thu Jul 14 12:45:51 1994
>%%%From: jnolan at tecsun1.tec.army.mil (Jim Nolan)
>%%%Subject: Re:mapgen
	... much original material deleted
>%%%make: Fatal error: Command failed for target `all'
>The mapgen src code was written, as I understand, to compile using the
>gcc compiler.  We "SCS" used the gcc compiler and the compile ran smoothly.
>>From what I can tell from your error message, the compiled library files
>can not be read correctly.  This is probably related to the compiler you are
>using and the fact that some include file can not be interpreted correctly.
>The gcc compiler is available on an ftp site.  I do not know the address.
>I recommend that you get gcc before going on.
>Jill
The original mapgen (as well as the one distributed on charon)  was (is)
VERY MUCH K&R and should be capable of being compiled on the ancient
Sun 4.xxx compiler.
I did not comment on the original message because the problems
may lay with non-mapgen related idiosyncrosies, notably, foreign "make"
systems.  It's best I stay out of it.
Gerald (Jerry) I. Evenden   Internet: gie at charon.er.usgs.gov
voice: (508)563-6766          Postal: P.O. Box 1027
  fax: (508)457-2310                  N.Falmouth, MA 02556-1027
