Still trouble w/ Solaris
George Taylor oregon at chaos.ATS.ORST.EDU
Mon Jul 18 11:34:47 EDT 1994
If it's fifos you need then the following will generate them for you.
(At least it works under SUN OS 4.1.3)
I lost mine too when using a tar file to place GRASS on a new disk
and the following was extracted from the GISGEN.sh script.  Run under
the Bourne shell with the account that GRASS was created from.
Wayne Gibson
Oregon State University
for i in a b
do
        fifo=0
        while test $fifo -lt 21
        do
                if test ! -f $GISBASE/dev/fifo.$fifo$i
                then
                /etc/mknod $GISBASE/dev/fifo.$fifo$i p
                chmod 0666 $GISBASE/dev/fifo.$fifo$i
                echo $GISBASE/dev/fifo.$fifo$i created
                fi
                fifo=`expr $fifo + 1`
        done
done
> >So I got past that problem.  But I get another error.
> >Graph_Set: can't open
> >Error - Can't set up pipe to graphics device.
> >Problem selecting x0. Will try once more
> >I get that error for both x0 and x1.  This is using d.mon on Solaris2.3 from
> >the moon binary release.  Any more words of wisdom?
> >-Stephen Dzurenko
> > e-mail: steve at ocesun1.oce.uri.edu
> Stephen,
> Did you rebuild the fifos?  It is my understatnding that they get "lost" in
> a tar.  Someone else will have to post on how to do that, but it is an
> operating system command.
> (The "fifos" are mysterious little beings that live in the device
> directories of GRASS code and binaries, where they slow down X signals in
> order to collect tolls or something.  Then they let the signals pass -- that
why
> it takes so long for things to draw, etc.  :-)   )
> Ron T - Estes Park, CO - ront at niwot.cnr.colostate.edu
