s.surf.tps too
Irina K. kosinov at uxa.cso.uiuc.edu
Wed Jul 27 15:09:19 EDT 1994
In info.grass.user you write:
>Hi,
Hello
>And while we're talking s.surf.tps, is there a way of getting it to output the
>error estimate surface instead of the actual surface?
Yes. If you want to get surface of deviations -- just output deviations
site file when you run s.surf.tps (it's one of the options in the new version)
and then run s.surf.tps on deviations file.
If you want crossvaliadtion error surface -- run s.surf.cr.2d on your
input site file and then run s.surf.tps on your resulting site file.
>Ta,
Irina
>Fred Watson
>PhD Scolar
>CRC for Catchmnet Hydrology
>Civil & Environ. Engineering
>Melbourne Univ.
>AUSTRALIA
