make Xgrass
    Special system engineer
    jytsai at iiidns.iii.org.tw
    Thu Jul 28 12:20:53 EDT 1994
In article <199407272129.QAA21507 at max.cecer.army.mil> you wrote:
: "Interact.c", line 877: warning: illegal combination of pointer and integer, op =
: "Interact.c", line 961: warning: illegal combination of pointer and integer, op =
: "Interact.c", line 1285: warning: illegal pointer combination
: "Interact.c", line 1545: primitive_class undefined
: "Interact.c", line 1545: arm_and_activate undefined
: "Interact.c", line 1552: primitive_class undefined
: "Interact.c", line 1552: arm_and_activate undefined
: "Interact.c", line 1559: primitive_class undefined
: "Interact.c", line 1559: arm_and_activate undefined
: *** Error code 1
: make: Fatal error: Command failed for target `OBJ.sun4/Interact.o'
: Current working directory /users/grass4.1/src/xgrass/libes/Xgi
: *** Error code 1
: make: Fatal error: Command failed for target `all'
: Can you tell me how can I do.
: Thanks in advance.
  What's the environment u use? Try to modify ur header file in src/CMD/head
by adding -DXM_1_1_BC to XCFLAGS. If it still did not work, u can inspect the
XmP.h and to find out the flag it should define in adavnce.
They call me brother wine, but I do'nt like wine so much.
E-mail address: jytsai at nlia5.csie.nctu.edu.tw
