Digitized contour lines
    martijn at scanner.frw.uva.nl
    Thu Jun  2 06:05:49 EDT 1994
On Wed, 1 Jun 1994, M.R. Lassche wrote:
> Trond masking does not work with r.surf.contour , but what you can do is make a mask and give it a value not equal to zero. Then patch this mask with your contour raster map.
> r.surf.contour will now skip the masked area because all the cells in the masked area have a value
> Hope this will work
> Ronnie
Although this will work, it is not a good idea, since the values in the
mask will be used to interpolate new cell values. Thus, you will get
incorrect height values in areas near the mask. A better solution would
be to make the region as small as possible, run r.surf.contour without a
mask, then cut the unwanted areas by r.patching a mask consisting of 0's
(You can also do this by setting the mask, then run r.mapcalc
old.dem=new.dem).
P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam
