sites to raster
Brian Culpepper
brian at cast.uark.edu
Thu Jun 2 13:30:17 EDT 1994
> Is there a way to convert a sites list to raster so as to keep the attributes
> of the sists lists intact? When I go through s.menu all I get is a 0/1
> image.
here goes,
" You can create a non-binary raster map
layer representation of your site list by creating the site
list in the format:
E|N| #n label
where E is the Easting, N is the Northing, and #n label is
the description field. The description field consists of a
pound sign # followed by the category value n to be
associated with the site's cell location, and the category
label label for n.
If the user does not include a description field starting
with
#n
beside the Easting and Northing on every line in the sites
list file, a binary raster map layer will be created
instead. In the binary raster file, each site will be
represented as the category value 1. Non-site cells will...."
- g.manual
Hope this helps,
R. Brian Culpepper Research Assistant
Center for Advanced Spatial Technologies (fax) 501 575-3846
Rm. 214 Ozark Hall (work) 501 575-6159
University of Arkansas brian at cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
