d.mon (fwd)
Sue Tewalt x6437
stewalt at ncrds.er.usgs.gov
Wed Jun 15 10:24:30 EDT 1994
Forwarded message:
> Message-Id: <9406150620.AA05848 at imt.ntou.edu.tw>
> Sender: grass-lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Precedence: Bulk
> Subject: d.mon
> Hi!
> I run the d.mon start=x1 and display "Graphics dirver [x1] is a already running",but cann't display the x1 monitor.
> Can you tell me how can I do.
> Thanks in advance.
Just try d.mon select=x1 if the monitor is visible, or stop=x1.
Otherwise--
Use the UNIX ps command to find the process number of the x1 monitor,
then use the kill command to stop the process. x1 should then be able to
be started.
