PROBLEMS Initializing grass!!!!
KLENKUS1 at VAXC.STEVENS-TECH.EDU KLENKUS1 at VAXC.STEVENS-TECH.EDU
Mon Jun 20 13:51:27 EDT 1994
Update on problem:
MY MACHINE seems to be confused.  During the envoking of grass,
it gives the following message.
Sorry, <MONITOR> is not a valid parameter
ERROR: Required parameter <input> not set:
(Name of the site file with input x,y,z).
Usage:
 g.gisenv [-d] input=name [devi=name] [treefile=name] [overfile=name]
   [elev=name] [slope=name] [aspect=name] [pcurv=name] [tcurv=
   [mcurv=name] [maskmap=name] [dmin=value] [zmult=value] [tension=v
   [mcurv=name] [maskmap=name] [dmin=value] [zmult=value] [tension=vFlags:utput partial derivatives
 -d   Output partial derivatives
Parameters:
 input   Name of the site file with input x,y,
     devi   Name of the output deviations site
 treefile   Output vector file showing segmentation
overfile   Output vector file showing overlapping
  elev   Output z-file (elevation)
  slope   Slope
(ect. ...)
Looks like an s.surf.tps program.  I was trying to put the
new s.surf.tps program in from the new interp library.
Anyone got a clue?
Kym M. Lenkus
