GRASS4.1 on SOLARIS 2.3
John Talcott
talcott at trg.saic.com
Wed Jun 29 21:18:55 EDT 1994
In article <Cs5up8.1FMs at yuma.ACNS.ColoState.EDU>,
ront at picea.CNR.ColoState.EDU (Ronald Thomas) wrote:
> >Yes - I successfully installed GRASS 4.1 under
> >SOLARIS 2.3. I did have a problem with the X driver.
> >d.mon start=x0 gave me an error message. After I set
> >the LD_LIBRARY_PATH environment variable to
> >/usr/ucblib d.mon worked OK. I haven't had any
> >other problems.
> >John C Talcott talcott at trg.saic.com
> John -- did you compile GRASS4.1 from source or did you use the
> pre-compiled binaries? If compiled, what compiler?
> Thanks!
I compiled GRASS from source using cc compiler.
Science Applications Intl. Corp. (SAIC)
10260 Campus Point Drive
San Diego CA 92121
(619) 546-6447
