ps.map
    Malcolm Williamson
    malcolm at cast.uark.edu
    Wed Mar  9 11:42:45 EST 1994
> After I create my output file using ps.map how do I print it?
> I am using a Sparcprinter with Newsprint.  Do I use lpr, pl
> and then filename.  I saw some discussion about plotter and
> plot.sh.
> Thanks for the help,
> Jim
With NewsPrint, you should be able to treat the PostScript file just like a text
file: lpr filename, or lpr -Pprinter_name filename (if you must specify your
printer).
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
