No subject
Susan Stitt susan at nps.gov
Mon Mar 28 10:32:40 EST 1994
>Date: Thu, 24 Mar 1994 21:14:01 +0000 (GMT)
>From: s0 at aldo.tmc.edu (Student Acct 0)
Subject: s.db.rim and RIM problem
>Organization: Univ. of Arizona Advanced Resource Technology Program
>Please let me know if you hve used s.db.rim to open a database created in
>RIM?  The database was exported to a text file and then imported for use
>with the s.db.rim command. The imported database is listed as available;
>however, I can't open it. The error message is
>RIM ERROR CODE #1: Unlisted Rim error
>message.
   >Thanks.
   >Sharon Des Rosiers, Applications Systems Analyst
Sharon,
  It has been a while since I have used RIM, however I do remember having
to design the screen layout for displaying the site records.  This can be
done with the .make command, or through menu item 13) "Make a new data
base and Management Functions".  If you re-imported without such a
definition file, then s.db.rim and v.db.rim can not recognize the data in
the file, although rim itself can use the file/data.  Hope this helps, and
solves the problem.  We have moved on to Informix and are enjoying the
relational capabilities available there.
Susan Stitt     National Biological Survey           sstitt at its.nbs.gov
                Information and Technology Services  (303)969-2596
