MAPGEN - HP 650C plotter
    Jill Schuler
    jschuler at ncg.scs.ag.gov
    Tue May 10 11:56:01 EDT 1994
%%%At the state office, we have a HP DesignJet 650C plotter.  I have been using
%%%this plotter to produce some maps but have had difficulty in utilizing more
%%%than 8 or 16 pens.
%%%Do you have a plotter driver design to work on a HP650C plotter?
%%%Chris Kendrick
%%%Soil Scientist/Database Manager - Missouri
%%%INTERNET: chrisk at mosoils.mo.scs.ag.gov  :  ckendric at bigcat.missouri.edu
Work has already been done to allow the user 255 pens with the hpgl
driver.  This change was included in the 4.0 GRASS version.
Essentially, the new driver is exactly the same as the hpgl driver
(not hpgl2) except you may have up to 255 different pens.  The driver
name is calhpgl (a b c d or e ) paper sizes.  See the mapgen 4.1
manual, Appendix I-a, plotter drivers. The color mapping for the pens
is hardware dependent.
I've been working on a driver to the hp650c that supports color postscript all
the way to e size paper.  It is called "hpcps" and currently supports 255
default pens.  Colors and widths can be user defined and are setup in two
support files (i.e., .colortable and .width).  The file formats are discussed
fully in Appendix I-a, .colortable.  This driver functions exactly as the
cps driver used by the Interface.
Hopefully,  I can get something going for the 4.13 release coming out
sometime in June.
Hope this helps.
Sincerely,
#  # #### #### ####      ######  #### ##### Jill R. Schuler
#  # #    #  # #  #      #      #     #     USDA
#  # #### #  # #### ### ####   #     ####   Soil Conservation Service
#  #    # #  # #  #        #  #         #   National Cartography and
#  #    # #  # #  #       #  #         #    GIS Center
#### #### #### #  #   ####  ###### ####     P.O. Box 6567
				            Ft. Worth, TX 76115
e-mail: jschuler at ncg.scs.ag.gov             Phone: (817) 334-5559 x3086
