New animation program
Bill Brown
brown at zorro.cecer.army.mil
Fri May 13 15:50:43 EDT 1994
I just put a new animation program for GRASS raster files on moon under
grass/incoming. It's just a quick port to X/Motif of a less user-friendly
but more versatile program we've been using in-house on our SGIs.
So you need X11 & Motif to compile. If you find it useful or have
suggestions for improvements, please let me know.
Oh yeah, the file is xganim.tar.Z
Here's the man page for it:
xganim <contrib> GRASS Reference Manual <contrib> xganim
NAME
_x_g_a_n_i_m - Raster File Animation Program
SYNOPSIS
xganim
xganim help
xganim view1=_n_a_m_e[,_n_a_m_e,...] [view2=_n_a_m_e[,_n_a_m_e,...]]
[view3=_n_a_m_e[,_n_a_m_e,...]] [view4=_n_a_m_e[,_n_a_m_e,...]]
DESCRIPTION
_x_g_a_n_i_m is a tool for animating a series of GRASS raster
files. At startup, a graphics window is opened containing
VCR-like button controls for: rewind, reverse play, step
back, stop, step forward, forward play, loop, swing, slower,
faster, show filenames, current frame no., and Exit. The
image is displayed above or to the left of the controls.
Each raster file is read into memory, then the animation is
played once beginning to end. The user may then replay the
series or play continuous animation by using the buttons.
The user may define up to four "views", or sub-windows, to
animate simultaneously. e.g., View 1 could be rainfall,
View 2 flooded areas, View 3 damage to bridges or levees,
View 4 other economic damage, all animated as a time series.
There is an arbitrary limit of 100 files per view (100
animation frames), but the practical limit may be less
depending on the window size and amount of available RAM.
The environment variable XGANIM_SIZE is checked for a value
to use as the dimension, in pixels, of the longest dimension
of the animation window. If XGANIM_SIZE is not set, the
animation size defaults to the rows & columns in the current
GRASS region, scaling if necessary to a default minimum size
of 600 and maximum of 900. The resolution of the current
GRASS region is maintained, independent of window size.
Resizing the window after the program is running will have
no effect on the animation size.
UNIX - style wild cards may be used with the command line
version in place of a raster file name, but it _m_u_s_t _b_e
_q_u_o_t_e_d.
Example:
xganim view1="rain[1-9]","rain1[0-2]" view2="temp*"
If the number of files differs for each view, the view with
the fewest files will determine the number of frames in the
animation.
COMMAND LINE OPTIONS
Parameters
_v_i_e_w_1
Raster file(s) for View1
_v_i_e_w_2
Raster file(s) for View2
_v_i_e_w_3
Raster file(s) for View3
_v_i_e_w_4
Raster file(s) for View4
BUGS
On some displays that need to use private colormaps, the
interface buttons may become difficult to see.
AUTHOR
Bill Brown, U.S. Army Construction Engineering Research
Laboratories (brown at zorro.cecer.army.mil)
NOTICE
This program is part of the _c_o_n_t_r_i_b section of the GRASS
distribution. As such, it is externally contributed code
that has not been examined or tested by the Office of GRASS
Integration.
2 U.S. Army CERL GRASS 4.1
