XGRASS illegal help data error
    Josef Fuerst
    fuerst at donau.boku.ac.at
    Tue May 17 16:05:45 EDT 1994
> The solution for your problem is probably one of the solutiopn to
> xgrass on HP 9000 machines. All you have to do is that you should
> get into the $(ETC)/xclip directory and remove or comment out all
> the lines that contain helpwidgetref:, I did this for all the files with
> a simple script.
> for i in *
> do
> 	cp $i /tmp/xclip.tmp
> 	awk -f":" '{if($1 != "helpwidgetref") print $0}' /tmp/xclip.tmp > $i
> io
> done
> Be careful here. Make a back up of the xclip directory beofre you attempt to
> do this.
> Good luck
> Nalneesh Gaur, River Forecast Center, TULSA
 Thanks, it works now. I just hoped ther was some easy way to keep the
 help functionality as intended.
 Josef Fuerst
Dipl.Ing. Dr. Josef Fuerst
Universitaet fuer Bodenkultur
Institut fuer Wasserwirtschaft, Hydrologie und konstruktiven Wasserbau
Nussdorfer Laende 11
A-1190 Wien
AUSTRIA
Tel: +43 1 3692924 360
Fax: +43 1 3692924 350
E-mail: fuerst at donau.boku.ac.at
