ps.select: THE END
Andrea Giacomelli
andreag at idra1.iar.polimi.it
Wed May 18 15:15:52 EDT 1994
> It seems that there is something wrong with your ps.select/list.c. Procedure
> ls_painters() is out of order. It checks out if the given name is relevant.
> As a quick fix you can commment out row 18 from your main.c and the checking
> should be disabled.
> Some more cleaver one should try to find out a better fix :)
> janne
> p.s. if you are using linux-grass and you don't have sources mail to me !
Eventually I went to modify the read_cfg.c file in ps.map sources, and I
changed the deafult paper params. .
This is because I will ALWAYS print on A4 paper, so I can avoid
using ps.select.
Now everything works fine (...until when?).
I thank you for your assistance and I hope to be able to give some help
back, if necessary (but I got still a lot to learn!)
Andrea G.
