R.SURF.CONTOUR and real numbers
Simon Cox
s.cox at dem.csiro.au
Tue May 24 02:24:34 EDT 1994
>Is it possible to produce a DEM with real data type
>(with 2 decimal numbers) by using R.SURF.CONTOUR,
>or must I transform the units of the input file
>from meters to centimeters?
At present, GRASS rasters are restricted to integer values, thus your idea
of multiplying up from metres to cm is the best thing. I believe there are
plans afoot to incoroporate this enhancement in GRASS version 5.
Simon Cox
____
__________________________________________________________________
Dr Simon Cox __ L
CSIRO Div. Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ,-' \ Geodynamics
Nedlands, WA 6009, Australia ( \ Cooperative
Phone +61 9 389 8421 X ___ / Research
Fax +61 9 389 1906 L,~' "\__/ Centre
s.cox at dem.csiro.au v
