Xgrass error in Solaris 2.3
    Brian Aker
    brian at tychonic.antioch.edu
    Sun May 29 13:58:07 EDT 1994
Hello all.
After finally getting Solaris 2.3 to run, I got the error:
X Error of failed request:  BadMatch (invalid parameter attributes)
  Major opcode of failed request:  78 (X_CreateColormap)
  Serial number of failed request:  265
  Current serial number in output stream:  266
Error - Can't set up pipe to graphics device.
Problem selecting x0. Will try once more
when I tried d.mon start=x0 from the Control Display Monitor.
Anybody ever seen this one, and have an answer?
If this in the FAQ, sorry, I haven't found it yet, but would love
to recieve a copy of it!
thanks
   Brian
_____________________________________________________________________________
Brian Aker			|		brian at jumpriver.antioch.edu
Yellow Springs, Ohio.		|		brian at antioch.edu
_______________________________/_\___________________________________________
You can't grep a dead tree.   /   \
