TOPMODEL in GRASS
Raymond Venneker
venn at geo.vu.nl
Tue Oct 4 06:59:24 EDT 1994
> There has been some discussion on this list before about using
> TOPMODEL in GRASS. Most of us have just figured that using the r.watershed
> was good for calculating the parameter "a".
> However, I have recently learned that it is important that the
> water be allowed to follow MULTIPLE FLOWPATHS for a reasonable accurate
> saturated area map. Has anyone implemented such a routine in GRASS?
> S. Chairat and J. Delleur have published a paper on this, but I don't know
> how to get their algorithm (S. Chairat is in Tunisia). I would be very
> interested in discussing this further with anyone.
> Jane Rossing
> jr20 at cornell.edu
Below are some references, see Costa-Cabral & Burges for an extensive
discussion on single/multiple flowpaths. Freeman contains an algorithm
(but note the difference of the power coefficient between Freeman and
Holmgren!). I have some preliminary code but *not* for grass because
there is not floating point raster support yet. You may contact me
directly if you need more info.
Could you provide a pointer to the Chairat/Deleur paper?
-Raymond (venn at geo.vu.nl)
[WRR: Wat. Resour. Res.; CG: Comp. & Geosc.; HP: Hydrol. Proc.]
@Article{b-costacabral-burges-94,
author = "M. C. Costa-Cabral and S. J. Burges",
title = "Digital Elevation Model Networks {(DEMON)}: A Model of
Flow over Hillslopes for Computation of Contributing and
Dispersal Areas",
journal = WRR,
volume = "30",
number = "6",
pages = "1681--1692",
year = "1994",
@Article{b-freeman-91,
author = "T. G. Freeman",
title = "Calculating Catchment Area with Divergent Flow Based
on a Regular Grid",
journal = CG,
year = "1991",
volume = "17",
number = "3",
pages = "413--422",
@Article{b-holmgren-94,
author = "P. Holmgren",
title = "Multiple Flow Direction Algorithms for Runoff Modelling
in Grid Based Elevation Models: An Empirical Evaluation",
journal = HP,
volume = "8",
pages = "327--334",
year = "1994",
@Article{b-quinn-et-al-91,
author = "P. Quinn and K. Beven and P. Chevallier and O. Planchon",
title = "The Prediction of Hillslope Flow Paths for Distributed
Hydrological Modelling Using Digital Terrain Models",
journal = HP,
volume = "5",
pages = "59--79",
year = "1991",
note = "Reprinted in Beven and Moore (Eds), 1992",
