Vista-eXceed X window manager
Malcolm Williamson malcolm at cast.uark.edu
Fri Oct 28 09:58:47 EDT 1994
> Hi,
>    We are trying to setup several PC's to display GRASS that is running on our
> Sun Server.  We are using Vista-eXceed for DOS version 3.3 on the PC and our
> Sun unit is running GRASS version 4.1 (Spring 1993) under SunOS Release 4.1.3.
> We get a window on the PC and start GRASS and open a seperate monitor window
> on the PC.  After setting the region we can have a vector plotted and GRASS
> claims it completes the plotting, however the plot is not displayed on the
> monitor window.  We can display the xclock graphic in an X window on the PC,
> so it looks like everything is set correctly, but maybe some configuration in
> GRASS is not set correctly.
>      Any help would be appreciated.
> 				Thank you.
> 				Louis Clarke, biologist
> 				U.S. Army Corps of Engineers
> 				Albuquerque District
> 				(505) 766-2776
> 				e-mail:lclarke at alb-co-r.swa.usace.army.mil
Hi, Louis
I know that this is probably too obvious, but did you remember to run d.erase
after changing your region? Also, are you familiar enough with the particular
vector files to know what is actually in them? Actually, a good test might be
to see if you can erase the monitor in a different color, ie, d.mon c=blue.
Hope that it turns out to be this simple!
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
