interpolating sparse arrays - where's the trend?
Simon Cox
s.cox at dem.csiro.au
Sun Sep 4 01:53:29 EDT 1994
I have been using s.surf.tps to interpolate through very sparse arrays.
This means that I generally do NOT have data points near to the edge of the
area. I realise that this means that I am "extrapolating" rather than
interpolating for these parts of the model. However, I am a bit surprised
at the results: for example, here is a sketch of an masked area with the
data
<--- 25km -------->
___________________
| / Only 3 data points!
| / I look at that & see a "trend" with +ve
| x 200 / values in the north and -ve values in
| / the south. However, s.surf.tps processes
| / this and produces a flat, level surface with
| / a +ve anomaly in the middle and a -ve
| -324 x/ anomaly in the SE, and a (almost) uniform
| / height edge all around. In other words, in
|-201x/ the "far field" only the mean level of the
| / data is seen in the interpolated surface,
| / and not the trend. Is this just a matter of
| / decreasing the tension, or does the tps method
| / inevitably fall back the the mean value
|/ outside the data?
Simon Cox
____
__________________________________________________________________
Dr Simon Cox __ L
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009, Australia ( \ Cooperative
Phone +61 9 389 8421 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
s.cox at dem.csiro.au 7
