v.digit problems: STILL
Ry Jones
rjones at halcyon.com
Wed Sep 14 20:40:44 EDT 1994
>The problem:
>Possible source of the problem:
> I have had this problem since I cp'd files from one disk to the
>other (whch was mounted as a directory) e.g.
>cp -R /usr/grass /mnt/usr/grass
yep, that did it.
go to your /mnt/usr/grass/dev directory, your fifos will be messed up. I
promise. The same thing happened to me, too.
The solution? I did a make devices from the top level (I think). I'm under
microsloth winblows, and I can't just hop over to my linux partition for the
directory.
If that's not it, just remember, it would be worse in Indiana.
rjones at halcyon.com net.viking OG+GOT;
GCS/S/O: d? H--- s+:+ g+ p1+ au-- a- w+++ v++ C++++ UL++++ P+ L++ 3- E---
N+
K++ W++ M-- V-- -po+ Y++ t !5 jx R G''' tv+ b+++ D++ B--- e+ u*--- h---- f
r+++ !n---- y++++ GeekCode v2.1 available: finger hayden at vax1.mankato.msus.edu
