Mapgen / sites / coordinates
Jill Schuler
jschuler at ncg.scs.ag.gov
Wed Sep 21 11:48:29 EDT 1994
%%%From: nra at cix.compulink.co.uk (N R A )
%%%(i) can I plot sites with their reference cf. the way I've done it using
%%%'ps.map' ?
%%%I've tried the 'make.sitefile' but that seems to create the site file - I
%%%can't see any equivalent to 'make.line', etc.
(1)
Use the make.symbol and make.label commands together. The command actually
calls the sites.to.geo command to create a georeferenced file under the
sites_geo directory. The contents are: Long\tLat\tDescription
%%%(ii) coordinate system. I've tried the 'make.grid' but that draw lat. &
%%%long. - being from the UK, I'd rather use the OS National Grid Reference
%%%system. I'm not sure what projection it is (if any - I thought it was a
%%%flat easting/northing grid with its 0,0 point just to the SW of the
%%%Sicily Isles).
(2)
The make.grid command (USGS grid command) only produces a geographic grid.
You can work around this using GRASS.
Use the v.mkgrid command to build a utm grid file showing your area.
Bring the grid vector file into mapgen using make.line.
Attach labels to the grid using the make.text command.
I have automated this procedure in the 4.13 Interface software for soil
map finishing. The software is designed to generate a 7.5 x 7.5 quad area
at most. However, the procedure could be expanded. The script is called
process.utm. It is designed to generate ticks and labels in the margin area
of the map.
%%%Is there some way to either persuade Mapgen to plot based on the
%%%coordinates of the data - it seems to convert them somehow into lat. &
%%%long. but shows Manchester area as being somewhere near the equator (3
%%%degrees lat.) in the Pacific (160 degrees W long.) ??
%%%Or what projection should I use - I'm no geographer - the projection is
%%%currently 'UTM' (Universal Transverse Mercator ??) and something called
%%%'Walsbeck ??'
(3)
If you build your geographic grid in mapgen and the grid notation is not
correct, then your original GRASS data is not defined correctly in the
PROJ_INFO file and WIND file.
Jill
# # #### #### #### ###### #### ##### Jill R. Schuler
# # # # # # # # # # USDA
# # #### # # #### ### #### # #### Soil Conservation Service
# # # # # # # # # # National Cartography and
# # # # # # # # # # GIS Center
#### #### #### # # #### ###### #### P.O. Box 6567
Ft. Worth, TX 76115
e-mail: jschuler at ncg.scs.ag.gov Phone: (817) 334-5559 x3086
