nohup and GRASS
Peter P. Petri
ppetri at sparta.sjsu.edu
Wed Sep 28 23:29:55 EDT 1994
Greetings,
I would like to run processes that are not killed when I logout. I have
tried using the nohup command outside of GRASS and receive the following
error message:
ERROR: GISRC - variable not set
My .grassrc file contains:
GIS: /local/grass
GISDBASE: /wma5/peterp/grass
LOCATION_NAME: lahonda
MAPSET: peterp
DIGITIZER: none
My question is what other variable do I need to set in this file? Is
this not the correct file to update
Thanks in advance...
Peter Petri
