sites w/ non-US char set
James Darrell McCauley
mccauley at ecn.purdue.edu
Thu Apr 20 08:00:00 EDT 1995
motte at xs4all.nl (motte at xs4all.nl) writes on 19 April 1995:
>Obviously you are aware that the incorporation of
>so-called diacritic signs under UNIX is still problematic for a lot of
>software, including GRASS and INFORMIX which I have been using
yes, but it is becoming less and less problematic. I've been playing
with Hebrew text (in X & emacs) and looking at setlocale(3c) and just
thought I'd get some sample sites from another continent.
>MacIntosh format, to UNIX-compatible format. So if you're planning to
>incorporate the extended ASCII set in GRASS, I am definitely in favour!
I thought that I would at least take a look at it (not making any
promises :)
>Philip Verhagen
Darrell
James Darrell McCauley, PhD http://soils.ecn.purdue.edu/~mccauley/
Dept of Agricultural Engineering mccauley at ecn.purdue.edu
Purdue University tel: 317.494.1198 fax: 317.496.1115
