s.surf.tps
Simon Cox
s.cox at dem.csiro.au
Wed Apr 12 08:00:00 EDT 1995
It's quite simple Ross: for historical reasons (a miscommunication between
CERL people) the sitefile to input into s.surf.tps has the format
easting|northing|#value
ie the third field has hashes prefixed. Yes, this does make it different
and incompatible with s.surf.idw. I understand that by GRASS-5 this will
all be cleared up (and hopefully the whole sites schemozzle will be much
cleaner, thanks to Darrell McCauley's new specification).
Good luck
Simon Cox
At 8:58 AM 12/4/95 -0500, Ross Searle wrote:
>I am trying to generate a DEM using s.surf.tps however the resulting raster
>always has a category value of "0" and a label of "no data". However when I
>run the same sites list through s.surf.idw it appears to generate a sensible
>surface. The format of my sites list is :-
>name|sitetest
>desc|test for sites list from contpts
>377395|7092510|480
>377461|7092519|480
>377506|7092531|480
>377581|7092606|460
>etc
>When I run s.surf.tps the following error messages for each site are
>displayed before it continues processing:-
>eg " 400 (line 484) site description not prefixed with '#'"
>Does anyone know where I might be going wrong !
>Thanks,
>Ross Searle
>Ross Searle Dept of Primary Industries
>Land Resources Officer PO Box 1143
> Bundaberg, 4670. QLD
>rossse at dpi.qld.gov.au
>PH (071) 537 888 FAX (071) 537 895
___________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
Phone +61 9 389 8421 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
s.cox at dem.csiro.au W
AGCRC info>> http://www.dem.csiro.au/simon/crc/intro.html
