mercator projections
William A Perkins
perk at phoebus.pnl.gov
Wed Apr 26 18:09:09 EDT 1995
>>>>> "Steve" == Steve Dzurenko <steve at ocean.oce.uri.EDU> writes:
Steve> Hello,
Steve> Is anyone a mercator projection location with GRASS? I am
Steve> trying to create a new location in a mercator projection
Steve> and I am not having much luck. In setting up the new
Steve> region, GRASS asks me for the units and a conversion factor
Steve> to meters. The units for a mercator projection are
Steve> degrees. Does GRASS convert the degrees to meters? And
Steve> the conversion factor is different for lat and lon. I am
Steve> confused. Has anyone successfully done this?
Steve> Thanks.
Steve> -Stephen Dzurenko
Steve> Ocean Mapping Division
Steve> Ocean Technology Center
Steve> Graduate School of Oceanography
Steve> University of Rhode Island
Steve> ph: 401 792-6853
Steve> fx: 401 792-6849
Steve> e-mail: steve at ocean.oce.uri.edu
Steve,
I've digitized, in GRASS 4.1.3, some NOAA charts which used the
Mercator projection. When setting up the GRASS location, I specified
the `merc' projection and GRASS asked me for an ellipsoid, a ``Central
Meridian'', and a ``Latitude of True Scale'' (these are in quotes
because I'm not sure what they mean). I used the *default* central
meridian and the ellipsoid and latitude of true scale specified on the
chart. After all that, it asked be for the ground units, which I
chose to be meters. I was later able to reproject the digitized charts
into UTM and state plane coordinates without difficulty. I can't tell
you how GRASS deals with the projection internally, but for me it
seemed to work.
Hope this helps.
Bill.
Bill Perkins
Battelle Pacific Northwest Laboratories
Environmental Sciences Center, Subsurface Flow and Transport
P.O. Box 999 MSIN K9-36
Richland, Washington, USA 99352 (509) 372-6131
wa_perkins at pnl.gov
