your mail
Casey Claiborne mskc at io.com
Sat Aug 19 08:00:00 EDT 1995
Hello and thank you for helping me :-)
>> (State)LOCATIONS - Texas, California, New York, etc.
>Again, these are directory names, and must follow appropriate UNIX naming
>conventions. Whether or not you could use a single state for each
>LOCATION depends upon your map projection. For state plane, this would
>not work, as many states have more than one zone. For example, Arkansas
>would require two distinct LOCATIONS in state plane, as there are two
>zones. UTM has similar problems, depending on the state. If you have not
>already done so, you need to learn about datums, ellipsoids & geoids, and
>projections - this is true for any GIS system.
Where could I locate such information?
Casey
One must note the importance of setting reasonable and achievable goals for
                    "If you aim for nothing, you'll hit it every time"
                               -Theodore Roosevelt
