LABELING to a monitor ???
Bonnie Weller
weller at osiris.cso.uiuc.edu
Fri Aug 4 08:00:00 EDT 1995
?05?09?16?pm%bnr?ca}?{199508040714?AA15970%xs1?xs4all?nl}@bnr.ca>
organization: University of Illinois at Urbana
reply-to: grassu-list at max.cecer.army.mil
newsgroups: info.grass.user
originator: daemon at ux1.cso.uiuc.edu
In info.grass.user you write:
>d.paint.labels should do the job; remember that d.paint.labels can only
>display labels previously defined with d.labels or p.labels. Check the
>label-file and your region settings, I suggest.
I created the files using p.labels. I also created the labels files
myself using the required parameters. As I said. The labels showed up
fine when using it in a script with p.map, but d.paint.labels did not show
up when I used it from the command line. (Nor did the labels show up when
I called the previously created file up using p.labels.) Weird huh ?
I'm probably missing some small detail but I can't figure out what.
I've read the damn manual at least 10 times. To my mind I am doing
it right.
Thank you for responding
Bonnie
weller at acca.nmsu.edu
