Rejected by Custodian
LE_MAILBOX
le_mailbox at qmgate.anl.gov
Tue Dec 19 07:00:00 EST 1995
Mail*Link(r) SMTP RE>patterns in ps.map
Hi Christine,
You can use the PBM filters to take the $HOME/paint.ppm output from p.map
and
pipe it through pnmtops and redirect to a file. This should get you something
to print with lpr. Good luck. Rick
On Mon, 18 Dec 1995, Christine Weiss wrote:
> Does anyone know why one can't use patterns in ps.map like you can p.map?
> Would anyone have any suggestions at getting around this problem? The
> only way around this that I can figure out is saving a map in sunraster
> format and then importing it into grass as a raster file, and then
ps.mapping
> the raster file. Any simpler solutions out there?
Rick Thompson- Research Specialist E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-8498
Ozark Hall Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
DISCLAIMER: Any opinions or comments about any product, organization,
or individual expressed in the above text are my own.
------------------ RFC822 Header Follows ------------------
Received: by qmgate_backup.anl.gov with SMTP;18 Dec 1995 20:25:27 -0600
Received: (from daemon at localhost) by diego.cecer.army.mil (8.7/8.7) id
RAA18372 for grassu-people; Mon, 18 Dec 1995 17:12:21 -0600 (CST)
Received: from max.cecer.army.mil (max.cecer.army.mil [129.229.20.254]) by
diego.cecer.army.mil (8.7/8.7) with SMTP id RAA18369 for
<grassu-list at diego.cecer.army.mil>; Mon, 18 Dec 1995 17:12:20 -0600 (CST)
Received: from cast.cast.uark.edu (cast.cast.uark.edu [130.184.75.44]) by
max.cecer.army.mil (8.6.9/8.6.9) with SMTP id RAA16607 for
<grassu-list at max.cecer.army.mil>; Mon, 18 Dec 1995 17:10:14 -0600
Received: from sisko.cast.uark.edu by cast.cast.uark.edu with smtp
(Smail3.1.28.1 #6) id m0tRoiO-000HpbC; Mon, 18 Dec 95 17:11 CST
Received: by sisko.cast.uark.edu (5.x) id AA01191; Mon, 18 Dec 1995 17:11:26
-0600
Date: Mon, 18 Dec 1995 17:11:25 -0600 (CST)
X-Sender: rick at sisko
Sender: grass-lists-owner at moon.cecer.army.mil
Reply-To: grassu-list at moon.cecer.army.mil
Precedence: Bulk
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: grassu-list at max.cecer.army.mil
Subject: Re: patterns in ps.map
In-Reply-To: <9512181823.AA04516 at nycparks.gov>
Message-Id: <Pine.SOL.3.91.951218170846.522B-100000 at sisko>
Mime-Version: 1.0
Content-Type: TEXT/PLAIN; charset=US-ASCII
