Orientation system
Rod Paterson
rgp%abba at haw.aberfoyle.oz.au
Fri Dec 8 07:00:00 EST 1995
> From grass-lists-owner%max.cecer.army.mil at munnari.oz.au Fri Dec 8 16:04:12 1
995
> Date: Thu, 7 Dec 1995 14:00:03 -0800
> I'm not so sure it's clockwise. If I have perfectly horizontal text,
> it seems counterintuitive that "increase the angle by 30 degrees"
> should make the text run downhill. If your users have a significant
> math background, they might expect you to follow _that_ convention
> (ccw=positive).
> Much depends on your actual application--scripting language? GUI to a
> cartographic tool? Are the users map readers who don't remember
> algebra, or mathematicians who don't know how to shoot a bearing?
> I think a better solution might be to get away from the terms
> plus/minus, and use east/west instead.
> Hal Mueller ManTech Environmental
> EPA, NHEERL-Western Ecology Division (541) 754-4490 Fax 754-4818
> 200 SW 35th Street halm at mail.cor.epa.gov
> Corvallis, Oregon 97333-4901 USA http://www.zilker.net/~hal/
The terms to use that are least ambiguous are left and right as one
travels along the vector azimuth.
East and West won't do it when the vector runs E->W or W->E.
I am in favour of the following:
If I wanted the symbol at +45 degrees I would expect it to be
to the the right of the vector as I look along it in its direction
of travel.
ie. | |
| v
For a polygon stored clockwise and a symbol angle of +45
all the symbols will be inside the polygon.
For a polygon stored anticlockwise and a symbol angle of +45
all the symbols will be outside the polygon.
Does GRASS always store polygons in the same direction?
The above strategy would conform to the way most earth
scientists think about angles. ie 0-360 degrees clockwise
However an applied mathematician using euclidean angles
would no doubt do the opposite.
Rod Paterson
Aberfoyle Resources Ltd
Level 31
525 Collins Street
Melbourne Vic., 3000
Phone: 61-3-2706666
Fax: 61-3-2706699
Email: rgp at aberfoyle.oz.au
