Orientation system
Simon Cox
S.Cox at solo.ned.dem.csiro.au
Fri Dec 8 07:00:00 EST 1995
At 2:00 PM 7/12/95, Hal Mueller wrote:
>I'm not so sure it's clockwise. If I have perfectly horizontal text,
>it seems counterintuitive that "increase the angle by 30 degrees"
>should make the text run downhill. If your users have a significant
>math background, they might expect you to follow _that_ convention
>(ccw=positive).
There are two conventions:
mathematicians have zero along y=0 and increment ccw
Geographers use "azimuth" with zero to the north and increment cw
As a famous ex-prime-minister of Australia (oxymoron?) once said
"Life wasn't meant to be easy!"
Simon Cox
_________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
Phone +61 9 284 8443 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
simon at ned.dem.csiro.au W
AGCRC info>> http://www.ned.dem.csiro.au/AGCRC/
