i.pca
Agustin Lobo alobo at ija.csic.es
Sat Dec 2 07:00:00 EST 1995
"" ..and the results from r.covar and m.eigensystem are dramatically
> different depending on whether a correlation or covariance matrix was used.""
As it has to be. If I recall correctly, i.pca uses the covar matrix. If
you are using m.eigensystem it's not difficult to check out: use r.mapcalc
and the eigenvectors.
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Marti Franques s/n
08028 Barcelona (Spain)
tel. 34 3 330 2716
fax. 34 3 411 0012
alobo at eno.princeton.edu
