projections in GRASS
    Simon Cox
    s.cox at dem.csiro.au
    Mon Feb 27 23:27:35 EST 1995
Vicente Sosa asks:
>        has anybody out there any experience transforming raster data
>between projections?
Here is what I posted to the list last September:
>I've just realised that Darrell McCauley's s.sample program solves the r.proj
>problem!  It might still be a bit involved, but the general flow would be:
>(i) in GRASS in the NEW projection, use r.stats -1gz to generate a list of
>desired cell locations.  Cell values will not be used so any layer can be used
>(ii) outside of GRASS use proj to convert this to a site list in the old
>projection
>(iii) in GRASS in the OLD projection use s.sample to generate a list of values
>at the positions in the site-list
>(iv) edit/awk this so that it can be swallowed by r.in.ascii - a small program
>might have to be written to make this quick
>(v) in GRASS in the NEW projection run r.in.ascii.
>Darrell has kindly implemented bilinear, nearest-neighbour and cubic
>interpolators, and since it works in the "implicity indexed" raster domain, it
>will run quick.
Simon Cox
___________________________________________________________
Dr Simon Cox                          __  \
CSIRO Exploration & Mining         ,~'  L_|\    Australian
39 Fairway, PO Box 437,         ;-'         \   Geodynamics
Nedlands, WA  6009  Australia   (            \  Cooperative
      Phone +61 9 389 8421      +    ___     /  Research
      Fax   +61 9 389 1906       L~~'   "\__/   Centre
s.cox at dem.csiro.au                         W
